Problem in Meshing
Dear Sir/Madam,
We are using a cORROSION module based on a complex imported geometry (steel cage in ac oncrete with five surface boundaries).After following the sequence of steps to simulate an OIL PLATFORM module in Corrosion, in the MESH section, I clicked Mesh button and went to SIZE option. Here after inputing various values in the MESH SETTING SECTION, the model crashes out. The total COMSOL software closes and we have reopen the module each time. We do not get any error message during closing and opening of the SOFTWARE PACKAGE
Thanking you,
Avijit Basu
Ryerson University, Toronto
Canada
2 Replies Last Post 26.03.2013, 01:57 GMT-4
Posted: 1 decade ago 25.03.2013, 22:58 GMT-4
Not enough information to help you. Perhaps you could attach the model if not too large, and I can try to mesh it for you.
Steven Conrad, MD PhD
LSU Health
Not enough information to help you. Perhaps you could attach the model if not too large, and I can try to mesh it for you. -- Steven Conrad, MD PhD LSU Health
Posted: 1 decade ago 26.03.2013, 01:57 GMT-4
meshing a complex structure is "delicate" and often requires some tweaking. Mostly one get away by meshing parts manually then finishing off the remaining. One thing to look after are "loops" try to cut these into several domains (at least two, and then mesh on and the other
Hi meshing a complex structure is "delicate" and often requires some tweaking. Mostly one get away by meshing parts manually then finishing off the remaining. One thing to look after are "loops" try to cut these into several domains (at least two, and then mesh on and the other -- Good luck Ivar
