comsol with matlab
I encountered a problem while using comsol. when I open the icon comsol with matlab, I got "??? Undefined variable "com" or class "com.comsol.model.util.ModelUtil.connect"."
Any ideas on what is wrong here?
Thank you in advance...
1 Reply Last Post 23.03.2013, 08:47 GMT-4
Posted: 1 decade ago 23.03.2013, 08:47 GMT-4
check the KB (knowledge base) about registering matlab and COMSOl links, there is also a press btton in the later versions under options preferences, one of the last tabs
This operation should be done once, normally done by the installation, might need to if you reload atlab, or update
Hi check the KB (knowledge base) about registering matlab and COMSOl links, there is also a press btton in the later versions under options preferences, one of the last tabs This operation should be done once, normally done by the installation, might need to if you reload atlab, or update -- Good luck Ivar
