Controlling my own boundaries
I am modelling a closed tube of air in 3D with a heating plate at one end of the tube. I have measured the temperature distribution across the heating plate as a function of time and location and would like to implement this in my model. I then use the boundary condition “Temperature” at the end of the tube with my measured profile, which is:
(4.1483*10^(-9)*t^2 -2.1712*10^(-5)*t -3.3232*10^(-2))*x^2 + (1.0432*10^(-8)*t^2 -1.5035*10^(-4)*t -0.11336)*y^2 + (-9.5557*10^(-9)*t^2 -2.3085*10^(-4)*t -1.028*10^(-1))*x + ( -1.0534*10^(-8)*t^2 + 2.3914*10^(-4)*t -0.1234)*y +(6.8938*10^(-10)*t^2 +4.1934*10^(-6)*t -5.4406*10^(-4))*x*y + ( 4.9445*10^(-8)*t^2 + 9.8562*10^(-3)*t + 21.079).
The heating plate is in the z-plane and x and y are both positive .
My problem is now, that this “heating profile” changes depending on which boundary conditions I use the tube walls. E.g. if I use thermal insulation for the tube walls, the temperature is practically constant across the heating plate.
How can I ensure that the heating profile of the plate does not changes at the end of the tube no matter what the other boundaries, in the tube, are?
Thank you for your time
Morten
2 Replies Last Post 13.03.2013, 11:54 GMT-4
Posted: 1 decade ago 07.03.2013, 01:25 GMT-5
cant you just select the heating plate boundary and give your expression in the "T" value entry but do not forget to adda ()[degC] all around as it looks for me that your equation is expressed in °C (or add +273.15[K]) ?
Often it's worth to create an analytical function in "Model - Definitions - Functions - analytical", then you can plot it too, and adapt the units ;) and call the function as an1(x,y,t)
Hi cant you just select the heating plate boundary and give your expression in the "T" value entry but do not forget to adda ()[degC] all around as it looks for me that your equation is expressed in °C (or add +273.15[K]) ? Often it's worth to create an analytical function in "Model - Definitions - Functions - analytical", then you can plot it too, and adapt the units ;) and call the function as an1(x,y,t) -- Good luck Ivar
Posted: 1 decade ago 13.03.2013, 11:54 GMT-4
Tank you, got it now
