Volume Integration and Surface Integration
What is the use of volume integration and surface integration for the parameters like temperature, pressure and velocity??
1 Reply Last Post 27.02.2013, 01:40 GMT-5
Posted: 1 decade ago 27.02.2013, 01:40 GMT-5
I'm not sure I understand you fully, indeed the integration of a temperature Field T(x,y,z,t) over a domain ends up with units K*m^3, as such not a usual physical global variable, but if you rather integrate over the volume rho*Cp*(T-T0) you get the increase in internal energy which is rather a usual and interesting variable
and to get the average temperature you need to integrate T over the volume and divide by the integration aver the volume of "1" i.e. the total volume. But now in V4 we have this in the average operator (if we consider the full domain)
This applies by similarity to p and v and many other variables
Hi I'm not sure I understand you fully, indeed the integration of a temperature Field T(x,y,z,t) over a domain ends up with units K*m^3, as such not a usual physical global variable, but if you rather integrate over the volume rho*Cp*(T-T0) you get the increase in internal energy which is rather a usual and interesting variable and to get the average temperature you need to integrate T over the volume and divide by the integration aver the volume of "1" i.e. the total volume. But now in V4 we have this in the average operator (if we consider the full domain) This applies by similarity to p and v and many other variables -- Good luck Ivar
