Fluidic Chamber Design
I have an Inlet in the form of a cylinder of radius 0.5mm. I need to tapper it so that that it at the bottom becomes a rectangle of length 1mm and height 0.1mm. How can I build this geometry? Thanks
1 Reply Last Post 29.01.2025, 13:20 GMT-5
Posted: 3 weeks ago 29.01.2025, 13:20 GMT-5
Updated: 3 weeks ago 29.01.2025, 13:20 GMT-5
Hello Hashem,
Use the Loft feature. It is available in the optional Design Module. To determine if the license you are using includes the Design Module, look undet File > Licensed and Used Products.
Jeff Hiller
Hello Hashem, Use the Loft feature. It is available in the optional [Design Module](https://www.comsol.com/design-module). To determine if the license you are using includes the Design Module, look undet File > Licensed and Used Products. Best, Jeff
Reply
