Seeing 3D mesh as 2D surfaces
I performed mesh in my 3D geometry and when I use clipping tool, I cannot see the 3D mesh part, I see only 2D surface meshes.
9 Replies Last Post 20.02.2025, 05:16 GMT-5
Posted: 1 month ago 03.02.2025, 04:02 GMT-5
I am not sure you can do that with the clipping tool, but under results (just run some empty/simple study) you can visualize the mesh and add filters to cut through it on a volume level.
René Christensen, PhD
Acculution ApS
www.acculution.com
info@acculution.com
Posted: 4 weeks ago 14.02.2025, 07:29 GMT-5
Thank you for your reply, but I tried it. Still I cannot see the 3D meshes I only see 2D surfaces.
Posted: 4 weeks ago 14.02.2025, 07:36 GMT-5
Are your sure you have not made a surface mesh on your domain then? Can you upload the file?
Acculution ApS
www.acculution.com
info@acculution.com
Posted: 3 weeks ago 17.02.2025, 09:02 GMT-5
Updated: 3 weeks ago 17.02.2025, 09:39 GMT-5
hi, sorry for late answer. i will send the file as soon as possible.
Posted: 3 weeks ago 18.02.2025, 06:56 GMT-5
Cool. Make sure that you try first in post-processing to have 3D Plot Group->Mesh, change Level from Surface to Volume, and then right-click and choose Filter and x>0.1 or something. That should give you a cut into the mesh.
Acculution ApS
www.acculution.com
info@acculution.com
Posted: 3 weeks ago 18.02.2025, 08:37 GMT-5
Yes, I tried filtering, still did not work. I am sending the file now.
Posted: 3 weeks ago 18.02.2025, 09:55 GMT-5
Updated: 3 weeks ago 18.02.2025, 09:55 GMT-5
To do what I suggest, you need to solve a Study. I put a some PDE/frequency study in there, and then in the results node you can see the volume mesh. Not sure if this can be done via the clipping feature without running a study, but you can ask COMSOL Support.
Acculution ApS
www.acculution.com
info@acculution.com
Posted: 3 weeks ago 19.02.2025, 07:23 GMT-5
Updated: 3 weeks ago 19.02.2025, 07:29 GMT-5
you need to solve a Study. I put a some PDE/frequency study ....
As I understand, a study is not necessary. Just right-click on Mesh 1 (after mesh build) and click 'Plot'.
Nice Greetings
>you need to solve a Study. I put a some PDE/frequency study .... As I understand, a study is not necessary. Just right-click on Mesh 1 (after mesh build) and click 'Plot'. Nice Greetings
Posted: 3 weeks ago 20.02.2025, 05:16 GMT-5
Build the mesh, then right-click on the Mesh 1 node and click 'Plot'. A mesh-plot will be created. There reduce 'Shrink Elements' to 0.9 and add Transparency as subnode.
In Applications Libraries->COMSOL Multiphysics->Meshing Tutorials->bracket_swept_mesh is a nice example for seeing 3D Meshes. Mesh Plot 1 is prepared but mesh must be build before.
Nice Greetings
>Still I cannot see the 3D meshes I only see 2D surfaces. Build the mesh, then right-click on the Mesh 1 node and click 'Plot'. A mesh-plot will be created. There reduce 'Shrink Elements' to 0.9 and add Transparency as subnode. In Applications Libraries->COMSOL Multiphysics->Meshing Tutorials->bracket_swept_mesh is a nice example for seeing 3D Meshes. Mesh Plot 1 is prepared but mesh must be build before. Nice Greetings
Reply
