How to assign a defined function to an electrode????
Muthuraman Chinnadurai
Hello Friends,
Am working on AC/DC Module and new to comsol. Am trying to define a rectangular pulse of 1200v with a duration of 1ns to an electrode and i wish your kind assistance for the same.
Thanks in advance.
3 Replies Last Post 01.04.2013, 10:47 GMT-4
Posted: 1 decade ago 08.02.2013, 12:37 GMT-5
Check the Definitions functions in V4, under "rect"angle You need todefine some "smoothings"
Hi Check the Definitions functions in V4, under "rect"angle You need todefine some "smoothings" -- Good luck Ivar
Posted: 1 decade ago 08.02.2013, 12:39 GMT-5
Muthuraman,
You can use predefined function for rectangular pulse. You can find this function under Definitions>Functions>Rectangle.
Alternatively, you can define rectangular pulse by yourself using built-in function flc2hs(x, scale), as shown in the attached picture.
Sergei
Muthuraman, You can use predefined function for rectangular pulse. You can find this function under Definitions>Functions>Rectangle. Alternatively, you can define rectangular pulse by yourself using built-in function flc2hs(x, scale), as shown in the attached picture. Regards, Sergei
Posted: 1 decade ago 01.04.2013, 10:47 GMT-4
Muthuraman,
Sergei
Thank you very much sir!!!
[QUOTE] Muthuraman, You can use predefined function for rectangular pulse. You can find this function under Definitions>Functions>Rectangle. Alternatively, you can define rectangular pulse by yourself using built-in function flc2hs(x, scale), as shown in the attached picture. Regards, Sergei [/QUOTE] Thank you very much sir!!!
