Microwave LC Filter
Trying to model microwave filter (superconducting). Need some ideas with steps for the mesh as nothing’s worked for me so far.
2 Replies Last Post 03.07.2024, 01:11 GMT-4
Posted: 1 month ago 02.07.2024, 08:37 GMT-4
Hello
If you do a search using the work microwave using the link for "models and application library" you will get numerous hits that may help you along. Perhaps this could be a starting point
https://www.comsol.com/model/coupled-line-bandpass-filter-12012
From what I saw in your model you do not have an airbox that surrounds your simulation so this is not helping. Look and read through many completed examples.
As for meshing, perhaps this would be a good case for a swept mesh. You could mesh the top layer of your traces using a triangular boundary mesh. You would then sweep that through the object. If you don't know what this means then look at some swept meshing files and video tutorials.
Hello If you do a search using the work microwave using the link for "models and application library" you will get numerous hits that may help you along. Perhaps this could be a starting point https://www.comsol.com/model/coupled-line-bandpass-filter-12012 From what I saw in your model you do not have an airbox that surrounds your simulation so this is not helping. Look and read through many completed examples. As for meshing, perhaps this would be a good case for a swept mesh. You could mesh the top layer of your traces using a triangular boundary mesh. You would then sweep that through the object. If you don't know what this means then look at some swept meshing files and video tutorials.
Posted: 1 month ago 03.07.2024, 01:11 GMT-4
Updated: 2 weeks ago 23.07.2024, 02:50 GMT-4
I have added the airbox. The mesh has been fairly done. But I get the Unifrom lumped port should be placed between two conductive boundaries - Feature: Lumped Port 2 & Lumped Port 1 when I run the study.
Reply
