how to measure max and min electric field of certain surface area ?
I simulated the insulation with a void , ( rectangular and circle) in 2D.
any way I want measure the max and min of electric field on the surface of the circle (certain surface) then how can I do THIS?
I can measure max and min in whole surface of my geometry but I need measure just at void surface.
thanks in advance
2 Replies Last Post 09.02.2013, 21:31 GMT-5
Posted: 1 decade ago 15.01.2013, 08:04 GMT-5
you have the min max plot option on a surface OR on a line or ..., but this will by default check all surfaces and all lines ... So you should make a subset with a Results - Data Set - select surface or select line and apply the min max plot thereon.
You can also use a Derived values node on a selection and ask for the min manx. Check the forum how to dump also the x,y,z location of the min aor max value
Hi you have the min max plot option on a surface OR on a line or ..., but this will by default check all surfaces and all lines ... So you should make a subset with a Results - Data Set - select surface or select line and apply the min max plot thereon. You can also use a Derived values node on a selection and ask for the min manx. Check the forum how to dump also the x,y,z location of the min aor max value -- Good luck Ivar
Posted: 1 decade ago 09.02.2013, 21:31 GMT-5
Dear Ivar
Thank you for you reply.
Dear Ivar Thank you for you reply.
