Which Physics should i choose????
Muthuraman Chinnadurai
Hello Friends,
Am trying to observe the increase in diameter of a hole for an applied electric field. Since am absolutely new to comsol Multiphysics i find it difficult to choose the type of physics to design with. Expecting your kind support at the earliest.
Thanks in advance.
2 Replies Last Post 10.01.2013, 09:21 GMT-5
Posted: 1 decade ago 10.01.2013, 03:28 GMT-5
1) Calculate the force on the boundary of the "hole" for a given applied electric field > Use AC/DC 2D ec, ef or mef (It depends on the exact nature of your problem).
2) Observe the increase in diameter of the "hole" > Use coupling with structural mechanics (but only after 1) is solved).
L. Queval
1) Calculate the force on the boundary of the "hole" for a given applied electric field > Use AC/DC 2D ec, ef or mef (It depends on the exact nature of your problem). 2) Observe the increase in diameter of the "hole" > Use coupling with structural mechanics (but only after 1) is solved). Good luck -- L. Queval
Posted: 1 decade ago 10.01.2013, 09:21 GMT-5
L. Queval
Thank you very much.
[QUOTE] 1) Calculate the force on the boundary of the "hole" for a given applied electric field > Use AC/DC 2D ec, ef or mef (It depends on the exact nature of your problem). 2) Observe the increase in diameter of the "hole" > Use coupling with structural mechanics (but only after 1) is solved). Good luck -- L. Queval [/QUOTE] Thank you very much.
