How I can add data for a solution to a new study?
Posted 23.12.2012, 17:54 GMT-5 Low-Frequency Electromagnetics, Heat Transfer & Phase Change, Structural Mechanics Version 4.1, Version 4.3a 8 Replies
Kind Regards.
No need to export the solution data from your transient thermal study. Just add a solid mechanics physics interface and a new study to the same model file (mph file). Do the following:
Right-click on Model 1 and select Add Physics
Add Solid Mechanics
Add the appropriate study type (I am assuming Stationary)
Right-cllick on Linear Elastic Material 1 and add Thermal Expansion
Expand Model Inputs and type "T" in the User defined list for Temperature (this couples the thermal expansion with the Temperature solved for by the Heat Transfer interface)
Apply boundary conditions to solid mechanics domains
Click on Study 2>Step 1: Stationary
In the Settings window, expand Values of Dependent Variables
Click check box for Values of variables not solved for
Change method to Solution
Change Study to Study 1, Time Dependent (your transient thermal study)
Change Time to 200 sec (or whatever time you want)
Josh Thomas
AltaSim Technologies
i pasted my temperature graph as follow, in the picture solution 3 is temperature field of heating,solution1 express
the cooling initial, why they are difference??
could you give me some advice
thank you and merry christmas
From looking at your screenshots, it's not clear to me exactly what your study set-up is. What do you mean by heating result and cooling result?
Would you be able to post your mph and give more explanation?
Josh Thomas
after modeling the induction heating,I would like to use the known temperature distribution to simulate a natural cooling or water cooling process. the cooling initial and the known temperature field should be same theoretically
my model is too big to paste,so could you give me your mail?
thanks a lot
To reduce mph file size, try clicking Edit>Clear All Meshes and Edit>Clear All Solutions. Then save.
Josh Thomas
thanks for your advice
my model is to big,so i paste a simplified 2D model with a similar Physical process,my actual model is a moving 3D one,the inductor move upon the plate
appreciate to your reply
I see what you are talking about and the reason is because when you divide your analysis into mutliple steps/studies the initial conditions for the cooling process must be "calculated" based on the input. For this reason, there is a slight difference due to the solver initializing the input conditions. This initialization step is important for some analyses where the initial field contiions need to be made consistent with the boundary conditions. In this case, it just makes a slight change to the values.
To avoid this, consider performing your analysis in one step. You can turn off the magnetic heat source by defining a step function that is smoothed and drops from 1 to 0. Right-click on Defintions and select Functions>Step. Then multiply your heating term by an appropriate step function so that it drops off after 10 seconds. Then run your simulation for 11 seconds. This will be a more realistic simulation of what's going on anyway.
See this thread for more info on using step functions:
www.comsol.com/community/forums/general/thread/29498/
Josh Thomas
Suggested Content
- BLOG How to Manage Multiple Solutions in COMSOL Multiphysics®
- KNOWLEDGE BASE Reducing the size of your COMSOL Multiphysics file
- KNOWLEDGE BASE What are batch licenses and how can I use them?
- KNOWLEDGE BASE Reducing the amount of solution data stored in a model
- FORUM How to add New Study
