How to applicate a Magnetic field
Hello
I'm beginner wuth Comsol and i wish to applicate a magnetic field into the metal structure of a surface acoustic wave sensor.
Thank you for your help
4 Replies Last Post 19.12.2012, 11:34 GMT-5
Posted: 1 decade ago 16.12.2012, 03:26 GMT-5
you can define a flux at the boundaries, or a magnetic field all in your volume, but with the latter will probably not give the best results taking into account that your objects probably change the field quite a bit.
But if you know the geometry of your magnetic source you could include it fully, bt then the model is larger, this could be an issue depending on how much RAM you have.
Last if you want to apply the model as above, but have RAM issues you could try to model it rather coarse, with a box where you want your detailed mode, than add a second model using only the boundary flux of the first calculation and model in detail your local effects
So many "way to Rome", it's just to choose which one ... ;)
Hi you can define a flux at the boundaries, or a magnetic field all in your volume, but with the latter will probably not give the best results taking into account that your objects probably change the field quite a bit. But if you know the geometry of your magnetic source you could include it fully, bt then the model is larger, this could be an issue depending on how much RAM you have. Last if you want to apply the model as above, but have RAM issues you could try to model it rather coarse, with a box where you want your detailed mode, than add a second model using only the boundary flux of the first calculation and model in detail your local effects So many "way to Rome", it's just to choose which one ... ;) -- Good luck Ivar
Posted: 1 decade ago 18.12.2012, 04:59 GMT-5
thank you for your answer. However,I wish to know how can I apply a magnetic field into a structure whose model: Structural Mechanics Module-Piezoplane stress? I failed to apply the magnetic field with Boundary settings with this type of model.
And I tried to make a model with AC / DC Module-inplane current Induction, Magnetic field, I found how to apply the magnetic field, but not to enter the specific parameters of each material as elastic matrices for example.
Thank you for your help.
Best regards
Hello, thank you for your answer. However,I wish to know how can I apply a magnetic field into a structure whose model: Structural Mechanics Module-Piezoplane stress? I failed to apply the magnetic field with Boundary settings with this type of model. And I tried to make a model with AC / DC Module-inplane current Induction, Magnetic field, I found how to apply the magnetic field, but not to enter the specific parameters of each material as elastic matrices for example. Thank you for your help. Best regards
Posted: 1 decade ago 18.12.2012, 05:12 GMT-5
in COMSOL each "physics" solves for specific dependent variables, so you must add in several physics or use "pre-cooked" "combined physics" for structural and magnetic field analysis
"solid" solves for _u_ = (u,v,w) the displacements, while the ACDC solves for Vm or A the magnetic scalar or vector potential and perhaps V the voltage
The material properties COMSOL asks for depends then on the physics you have selected
If you choose several physics, then you must also link yourself the physics over the boundaries or the domains, whatever applies
Hi in COMSOL each "physics" solves for specific dependent variables, so you must add in several physics or use "pre-cooked" "combined physics" for structural and magnetic field analysis "solid" solves for _u_ = (u,v,w) the displacements, while the ACDC solves for Vm or A the magnetic scalar or vector potential and perhaps V the voltage The material properties COMSOL asks for depends then on the physics you have selected If you choose several physics, then you must also link yourself the physics over the boundaries or the domains, whatever applies -- Good luck Ivar
Posted: 1 decade ago 19.12.2012, 11:34 GMT-5
Thankyou for your answer,
I wish to know how could I plot the admittance as function of frequency and magnetic field applied to a surface of a resonator using the model: Inplane induction Current magnetic field.
I'am using COMSOL 3.5a.
Thank you,
Best regards
Thankyou for your answer, I wish to know how could I plot the admittance as function of frequency and magnetic field applied to a surface of a resonator using the model: Inplane induction Current magnetic field. I'am using COMSOL 3.5a. Thank you, Best regards
