Permanent magnet_Failed to find a solution-Reg
Sambasivarao Kambala Non-destructive testing
Hello all, This is Siva. Recently started COMOL (6.0 version) for 2D modelling of the permanent magnet field distributions inside the ferrites and magnetic materials. I was able to define : 1. Geometry 2. Materials (air, soft iron) 3. Physics (magnetic fields, no currents) 4. Mesh well 5. While computing the model I got the following error The relative error (0.018) is greater than the relative tolerance. There was a warning message from the linear solver. Iterative refinement triggered. Returned solution is not converged. Not all parameter steps returned.
I tried all possible ways but i couldn't succeed. I have attached the model. Kindly help me the same. Looking forward to your kind reply.
Thanks & Regards, Siva
4 Replies Last Post 25.01.2024, 09:41 GMT-5
Posted: 10 months ago 24.01.2024, 12:31 GMT-5
Hi Siva,
assign a Zero Magnetic Scalar Potential BC to one of the points in your model and it will converge.
Cheers Edgar
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
Hi Siva, assign a Zero Magnetic Scalar Potential BC to one of the points in your model and it will converge. Cheers Edgar
Posted: 10 months ago 24.01.2024, 13:12 GMT-5
Hi Edgar J. Kaiser, Thanks for your quick reply and suggestion.
**Is it under magnetic field, no currents --> initial values? If the above one is correct, then in my model it is 0 only. **
Otherwise please let me know where to change these values. Looking forward to your kind reply.
Hi Edgar J. Kaiser, Thanks for your quick reply and suggestion. **Is it under magnetic field, no currents --> initial values? If the above one is correct, then in my model it is 0 only. ** Otherwise please let me know where to change these values. Looking forward to your kind reply. Thanks & Regards, Siva
Posted: 10 months ago 24.01.2024, 13:26 GMT-5
You must add an additional BC. You find it under the 'Points' BCs.
Edgar J. Kaiser
www.emphys.com
Posted: 10 months ago 25.01.2024, 09:41 GMT-5
Thank you very much Edgar J. Kaiser for your kind suggestions. Its working now.
