Maximum of multiple curves
Hello All, Currently I am modeling semiconductor devices and encountered an issue when trying to extract data for postprocessing. I have plotted the IV and PV curves of my device and want to extract the maximum power point. I created a parametric sweep to test the effects of different dopant concentrations and device geometries so there are in total over 100 curves I need the MPP for. When I plot the curve and use a graph marker, I am only given maxima from one curve. I tried to impliment a nonlocal coupling but this just returns a zero value. I have read that I need to change the discretization in the semiconductor physics settings, but I was wondering if there was a way to get the data I need without taking the time to recompute the model. If not what discretization setting should I use? Any help would be appreciated.
1 Reply Last Post 08.12.2023, 07:21 GMT-5
Posted: 8 months ago 08.12.2023, 07:21 GMT-5
Do you want the graph marker to extract the maximum over all curves instead of one maximum per curve?
