Can't use variable defined in 'Global Definitions' within a Waveform definition
I have defined 'tau' in Global Definitions as a variable = 40000*3600*24*365.25[s]
I have created a Waveform also in Global Definitions (and in local definitions just to check), with angular frequency = 2*pi/tau.
It does not like it: 'Unknown variable name' when I try to plot my Waveform.
If instead I substitute '2*pi/( 40000*3600*24*365.25)', then it's fine.
Why is this?
Ben.
3 Replies Last Post 12.11.2012, 17:47 GMT-5
Magnus Ringh COMSOL Employee
Posted: 1 decade ago 12.11.2012, 04:12 GMT-5
You can define 'tau' as a global parameter (Global Definitions>Parameters) instead. The use of variables in function definitions is not supported because in general, variables can depend on time and space variables.
Magnus Ringh, COMSOL
Hi, You can define 'tau' as a global parameter (Global Definitions>Parameters) instead. The use of variables in function definitions is not supported because in general, variables can depend on time and space variables. Best regards, Magnus Ringh, COMSOL
Posted: 1 decade ago 12.11.2012, 14:19 GMT-5
you can also use better the internal units as you seem to have 40'000 years there and there should be a unit for time in seconds, minutes, hours, days, ... check the doc
Hi you can also use better the internal units as you seem to have 40'000 years there and there should be a unit for time in seconds, minutes, hours, days, ... check the doc -- Good luck Ivar
Posted: 1 decade ago 12.11.2012, 17:47 GMT-5
Thank you Magnus, I see it now.
Ivar, yes it seems I can enter 40000[yr] instead, thanks.
Ben.
Thank you Magnus, I see it now. Ivar, yes it seems I can enter 40000[yr] instead, thanks. Ben.
