problem in view
Dear all ,
I created a two coil system , primary with six number of turns and secondary with one turn , primary place at 0.4 m and secondary placed at 0.38 m , when i simulated before it is showing the both coils (effect), now i dont know what happend ..it showing in primary coil of six turns , please let me know to view problem
Model attached
kishore Naik Mude
2 Replies Last Post 08.11.2012, 07:14 GMT-5
Posted: 1 decade ago 08.11.2012, 06:21 GMT-5
start rather with a current density, the single & multiple coil physics are complex BC's and you need to fully master them to be sure you use them correctly, read carefully the doc a few times
use a mapped mesh on the INF domains
make your mesh finer along the cut line in the center and I would use a 2 or 4 times smaller max mesh size for the air domain
Hi start rather with a current density, the single & multiple coil physics are complex BC's and you need to fully master them to be sure you use them correctly, read carefully the doc a few times use a mapped mesh on the INF domains make your mesh finer along the cut line in the center and I would use a 2 or 4 times smaller max mesh size for the air domain -- Good luck Ivar
Posted: 1 decade ago 08.11.2012, 07:14 GMT-5
Thanks Ivar
kishore Naik Mude
Thanks Ivar -- kishore Naik Mude
