How to get second and third eigenfrequancy values from Eigenfrequency study for optimization?
Михаил Кособоков
How to get second and third eigenfrequency values from Eigenfrequency study for for use in objective function. "freq" - is the first frequency, but what is the names of the ather calculated values?
3 Replies Last Post 19.07.2023, 05:27 GMT-4
Kristian Ejlebjærg Jensen COMSOL Employee
Posted: 1 year ago 18.07.2023, 02:44 GMT-4
freq is the frequency of the solution. There is no variable for the number of the frequency, but if you know the frequency is between 1 and 2 Hz, you can write
if(abs(freq-1.5[Hz])<0.5[Hz],freq,0) as the objective. Then the objective for the other frequencies will be set to zero.
Best regards, Kristian E. Jensen Technical Product Manager, Optimization
Hi freq is the frequency of the solution. There is no variable for the number of the frequency, but if you know the frequency is between 1 and 2 Hz, you can write if(abs(freq-1.5[Hz])
Михаил Кособоков
Posted: 1 year ago 19.07.2023, 04:45 GMT-4
Updated: 1 year ago 19.07.2023, 04:49 GMT-4
Thenk you for idea!
But I found an option using functions "withsol" and "setind" from here:
https://www.comsol.com/forum/thread/129793/could-i-use-a-comsol-eigenfrequency-mode-result-as-initial-value-of-a-time-depen
withsol('sol123',freq,setind(lambda,N))
where N - 1, 2, 3 .... is the mode number. I'm not shure that it is correct, but the objective function works correctly and I get the correct fitting parameters.
Despite this, the COMSOL highlights the expression of the objective function in orange and writes a comment: "Unknow variable root.lambda".
Thenk you for idea! But I found an option using functions "withsol" and "setind" from here: https://www.comsol.com/forum/thread/129793/could-i-use-a-comsol-eigenfrequency-mode-result-as-initial-value-of-a-time-depen withsol('sol123',freq,setind(lambda,N)) where N - 1, 2, 3 .... is the mode number. I'm not shure that it is correct, but the objective function works correctly and I get the correct fitting parameters. Despite this, the COMSOL highlights the expression of the objective function in orange and writes a comment: "Unknow variable root.lambda".
Posted: 1 year ago 19.07.2023, 05:27 GMT-4
That is probably correct. You can disregard the objective warning for special parameters like "lambda". I thought you wanted to perform gradient based optimization where the withsol() operator would give a wrong gradient, but it should work fine for gradient free optimization.
Optimization
Hi That is probably correct. You can disregard the objective warning for special parameters like "lambda". I thought you wanted to perform gradient based optimization where the withsol() operator would give a wrong gradient, but it should work fine for gradient free optimization. Best regards, Kristian E. Jensen Technical Product Manager, Optimization
