Bjorn Bretz
COMSOL Employee
1 year ago
31.05.2023, 10:46 GMT-4
Dear Shyam,
You can write a model method that computes the ratio between the lengths of the shortest and longest edges of a mesh element and then determines the minimum of these ratios. This method needs to use low level mesh information that you can retrieve from the Java API.
Dear Shyam,
Dave Greve
Certified Consultant
1 year ago
31.05.2023, 12:35 GMT-4
I'm curious, what is mesh bias and how does Ansys compute it?
Comsol has (among other things) a Mesh Quality figure of merit.
1 year ago
01.06.2023, 00:58 GMT-4
Updated:
1 year ago
01.06.2023, 09:28 GMT-4
Thanks Bjorn for your reply. Actually at this time I do not know how to use model method to work on mesh information. I will see, thanks.
Dear Dave, Bias factor is the ratio of the largest edge size to the smallest. In Ansys it directly gave under the mesh quality section.
Henrik Sönnerlind
COMSOL Employee
1 year ago
01.06.2023, 08:12 GMT-4
Updated:
1 year ago
There are several mesh quality measures in COMSOL. The one called 'Volume versus length' (variable name qualvollength) serves the same purpose as 'bias factor' measuring the mesh anisotropy. The numbers that it returns are not the same though.
Henrik Sönnerlind
COMSOL
There are several mesh quality measures in COMSOL. The one called 'Volume versus length' (variable name *qualvollength*) serves the same purpose as 'bias factor' measuring the mesh anisotropy. The numbers that it returns are not the same though.
