1 year ago
21.01.2023, 13:41 GMT-5
overview of the process:
Create a 3D model of the structure in the COMSOL Model Builder, and define the geometry, material properties, and boundary conditions.
Add the Solid Mechanics interface to the model to simulate the mechanical behavior of the structure.
Add the Phase Field Damage interface to the model to simulate crack propagation. This interface uses a scalar field variable, called the phase field, to represent the crack.
Add the Adhesion/Decohesion interface to the model to simulate the debonding behavior of the structure. This interface uses a scalar field variable, called the decohesion field, to represent the debonding.
Couple the Solid Mechanics, Phase Field Damage, and Adhesion/Decohesion interfaces to simulate the simultaneous effects of mechanical loading, crack propagation, and debonding.
Solve the model and post-process the results to analyze the crack propagation and debonding behavior of the structure.
1 year ago
26.01.2023, 17:31 GMT-5
Updated:
1 year ago
26.01.2023, 17:32 GMT-5
Thank you for your suggestion. You stated "Couple the Solid Mechanics, Phase Field Damage, and Adhesion/Decohesion interfaces". Is there any way to couple these? Because I followed all the steps described but the solution did not converge. Received this message " Feature: Stationary Solver 1 (sol1/s1)
Failed to find a solution for all parameters,
even when using the minimum parameter step.
In Displacement Field:
Not all parameter steps returned"
