Need help with Heat Transfer Optimization
Posted 16.09.2012, 22:51 GMT-4 Heat Transfer & Phase Change, Optimization Version 4.3 2 Replies
Hello:
I tried to simulate a heat transfer problem with large glass substrate sitting on top of an Aluminum plate with 3 heating zones: inner, outer and rim.
My goal is to find out the heating power setting for each heaters which will provide a uniform temperature profile across the glass substrate. I used Heat Transfer in Solids, defined 3 Heat Sources: Inner, Outer, and Rim.
In Optimization Node: I define 2 Points Integral Objective one at the corner, and one at the center of the glass with Objective expression as (T-Tsetpoint)^2 as suggested by Ivar on another optimization post. I then define 3 Global Control Variables for the 3 Heat Sources: inner, outer and rim.
Is this the right set up for the optimization module?
How do I find out what Heat source parameters are to make the glass temperature uniform?
Your help is appreciated.
Tac.
Tac.
2 Replies Last Post 17.09.2012, 03:51 GMT-4
