How to export the x,y,z coordinates
I created 7x7x7 cubical shape and want to export the x,y,z coordinates in the pattern that I want as attached. Please help me.
1 Reply Last Post 24.08.2012, 19:11 GMT-4
Posted: 1 decade ago 24.08.2012, 19:11 GMT-4
You can get nodal or integration point coordinates through a simple command in matlab, if this is what you are seeking. But you can put it in any format.
% have to load mph here
model = mphload('filename');
info = mphxmeshinfo(model,'solname', 'sol1', 'studysteptag', 'st1');
'info' is a structure and has all information.
I guess you could also export directly from the GUI in mphtxt format which should give similar information, but I have never used this.
Suresh
Hi, You can get nodal or integration point coordinates through a simple command in matlab, if this is what you are seeking. But you can put it in any format. % have to load mph here model = mphload('filename'); info = mphxmeshinfo(model,'solname', 'sol1', 'studysteptag', 'st1'); 'info' is a structure and has all information. I guess you could also export directly from the GUI in mphtxt format which should give similar information, but I have never used this. Suresh
