Level Set Method: Unable to Re-compute
I'm using two-phase flow, level set to simulate mixing of two fluids (gases) and got my model to run (is not correct in current state but did run), however, when I make a small change, I cannot get it to compute. I tried clearing all meshes, all solutions and resetting, but it still doesn't work.
Any thoughts?
1 Reply Last Post 22.08.2012, 05:11 GMT-4
Posted: 1 decade ago 22.08.2012, 05:11 GMT-4
Hi Lindsey
Did you solved this problem already? Try to delete all solvers and make new ones with "show default solver".
Best regards
Tero
Hi Lindsey Did you solved this problem already? Try to delete all solvers and make new ones with "show default solver". Best regards Tero
