Compression simulation with complex shape
I want to do an automated compression simulation of a complex shape, but it doesn't have a simple top or bottom, so prescribed displacement + fixed constraint won't work. I've been trying to use Body Load, but it seems to need a fixed constraint on the bottom still. Essentially: is there a way to do a compression simulation that works regardless if you change the geometry?
0 Replies Last Post 09.06.2022, 14:24 GMT-4
Hello Cal Friedman
