semiconductor module-converence error
The below post is related to an archived discussion
hi, earlier i got maximum number of iterations reached as an error, then i set the maximum number of iterations to 1000 and tolerence factor to 0.1. but still iam getting the below error.......(iam a beginner) [starUndefined value found. - Detail: Undefined value found in the equation residual vector. There are 6 degrees of freedom giving NaN/Inf in the vector for the variable comp1.Ne. at coordinates: (6.34493e-10,5.69378e-10,7.50039e-09), (2.11498e-10,1.03454e-09,7.09418e-09), (2.11498e-10,6.97749e-10,6.28772e-09), (2.11498e-10,1.83066e-09,7.32907e-09), (3.80885e-09,4.64104e-09,7.30372e-09), ...
There are 11 degrees of freedom giving NaN/Inf in the vector for the variable comp1.Ph. at coordinates: (2.18007e-09,3.78832e-09,9.57803e-09), (2.47047e-09,4.21299e-09,1.05763e-08), (6.34493e-10,5.69378e-10,7.50039e-09), (2.93233e-09,4.52549e-09,9.91643e-09), (2.73507e-09,4.14165e-09,9.33838e-09), ... t here]
thank you
0 Replies Last Post 21.05.2022, 03:52 GMT-4
Hello Rudravaram Srikanth
