1D-plot (line graph)
Thongchai Asavaparjukul
I am a new ComSol user.
I have simulated the model and got the result plotting in line graph.
I would like to have a result data in table (with xy-coordinate)
How can I do this?
Thank you very much.
3 Replies Last Post 09.08.2012, 10:57 GMT-4
Posted: 1 decade ago 08.08.2012, 10:59 GMT-4
Hi Thongchai,
I think I'm having a similar problem and I found a non-perfect solution. Please read both posts I made in this thread: www.comsol.com/community/forums/general/thread/30781/
Put simply, my strategy is to go to Results > Export (right click export), then > Data. You have to type in the expressions you want to export. This has worked for me with one exception: instead of getting 1 row with 9 columns (each column being a data point). I got 9 columns with 10s of thousands of rows. Where all the rows are redundant (they contain the same information as the first row). It's kind of annoying because the file size is much larger than it needs to be, but at least it works.
I hope that helps.
-Steve
Hi Thongchai, I think I'm having a similar problem and I found a non-perfect solution. Please read both posts I made in this thread: http://www.comsol.com/community/forums/general/thread/30781/ Put simply, my strategy is to go to Results > Export (right click export), then > Data. You have to type in the expressions you want to export. This has worked for me with one exception: instead of getting 1 row with 9 columns (each column being a data point). I got 9 columns with 10s of thousands of rows. Where all the rows are redundant (they contain the same information as the first row). It's kind of annoying because the file size is much larger than it needs to be, but at least it works. I hope that helps. -Steve
Posted: 1 decade ago 08.08.2012, 11:43 GMT-4
Dear Steve,
Thank you very much, now it is working perfectly for me!
I would have another question, if I want to put this output data result as an input of another structure for Solid Mechanics Interaction module, how can I import it?
Again, Thank you very much.
Best Regards,
Thongchai Asavaprajukul
Dear Steve, Thank you very much, now it is working perfectly for me! I would have another question, if I want to put this output data result as an input of another structure for Solid Mechanics Interaction module, how can I import it? Again, Thank you very much. Best Regards, Thongchai Asavaprajukul
Posted: 1 decade ago 09.08.2012, 10:57 GMT-4
Unfortunately, I'm also a beginner with COMSOL; I'm not sure I can help you out. I've been working with microfluidics so I don't know anything about structural mechanics.
