Ba0.6Sr0.4TiO3 material properties as dielectric material for capacitor
Hi I am an absolute beginner to Comsol and I am working on thin film capacitor simulation.
Does anyone work with Ba0.6Sr0.4TiO3 as a dielectric material?
I want to simulate the capacitance of capacitor but I do not know what properties to set
in Ba0.6Sr0.4TiO3 material..
Could anybody help me on this?
Thank you
5 Replies Last Post 25.07.2012, 20:14 GMT-4
Posted: 1 decade ago 25.07.2012, 00:29 GMT-4
Any suggestion or comment will be very helpful :)
Posted: 1 decade ago 25.07.2012, 02:12 GMT-4
material properties, particularly for multi physics are often difficult to find. probably here are not many out here reading and using your material, or it's perhaps also that that kind of material has properties that are very much deposit technology dependent. The bst is to seach the scientific litterature, or matweb or whatever to get the basic material properties
Hi material properties, particularly for multi physics are often difficult to find. probably here are not many out here reading and using your material, or it's perhaps also that that kind of material has properties that are very much deposit technology dependent. The bst is to seach the scientific litterature, or matweb or whatever to get the basic material properties -- Good luck Ivar
Posted: 1 decade ago 25.07.2012, 03:52 GMT-4
Thank you Ivar :)
I have searched the BST material properties, however I am not sure which properties are important to include.
Thank you Ivar :) I have searched the BST material properties, however I am not sure which properties are important to include. [QUOTE] Hi material properties, particularly for multi physics are often difficult to find. probably here are not many out here reading and using your material, or it's perhaps also that that kind of material has properties that are very much deposit technology dependent. The bst is to seach the scientific litterature, or matweb or whatever to get the basic material properties -- Good luck Ivar [/QUOTE]
Posted: 1 decade ago 25.07.2012, 16:17 GMT-4
that all depends on the physics you choose and the variables you scan ofr your model:
- can you do with scalars ?,
- do you need anisotropic values? ,
- does the temperature T have an inluence ?,
- the electric field ?
- hte magnetic field ?
In anycase start simple, then complexify when the simple model works and add one level at the time, this given best chances to converge
Hi that all depends on the physics you choose and the variables you scan ofr your model: - can you do with scalars ?, - do you need anisotropic values? , - does the temperature T have an inluence ?, - the electric field ? - hte magnetic field ? - ... In anycase start simple, then complexify when the simple model works and add one level at the time, this given best chances to converge -- Good luck Ivar
Posted: 1 decade ago 25.07.2012, 20:14 GMT-4
Thank you so much for your advice..
I'll try from a simple start then.
Have a good day
Rheza
Thank you so much for your advice.. I'll try from a simple start then. Have a good day == Rheza
