Dates on x-axis
Hallo,
Is it possible to put dates on the x-axis of a result (plot) in COMSOL? Right now I have hours adding up, but I want them to be times on specific dates.
Thanks for helping me out!
Kind regards, Simone
2 Replies Last Post 05.03.2022, 11:54 GMT-5
Posted: 2 years ago 05.03.2022, 00:45 GMT-5
Well, apparently you can use days as the units of time. That's pretty similar to using dates, right? In plotting the values from a time domain simulation in post processing, you can expand x-Axis Data and choose your units. See the attached partial screen shot. If that's not good enough and you can't find another way, then perhaps it would be easier for you to export the plotted data to Excel, or something like that?
Well, apparently you can use *days* as the units of time. That's pretty similar to using dates, right? In plotting the values from a time domain simulation in post processing, you can expand x-Axis Data and choose your units. See the attached partial screen shot. If that's not good enough and you can't find another way, then perhaps it would be easier for you to export the plotted data to Excel, or something like that?
Posted: 2 years ago 05.03.2022, 11:54 GMT-5
One option may be to generate annotations by a respective JAVA method.
Cheers Edgar
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
One option may be to generate annotations by a respective JAVA method. Cheers Edgar
