Issues about settlement of condition-The temperature change input of an isothermal body
Hello. My simulation is for a packaged electronic component (3D), the main structure of which is the chip, the pin and the package structure. I would like to simulate** the temperature of the package structure and the pins as a function of the chip temperature**. The chip is assumed to be isothermal. The problem encountered is that the chip is a 3D isothermal body and it is not possible to impose changing temperature conditions through the temperature boundary (face boundary). Here I would like to inquire on setting up the multi-physics field conditions.
looking forward to replys.
2 Replies Last Post 28.02.2022, 09:04 GMT-5
Posted: 3 years ago 25.02.2022, 11:57 GMT-5
Zhongchao,
I would think that this task should be an easy one, but it is not really clear to me what the problem is.
Cheers Edgar
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
Zhongchao, I would think that this task should be an easy one, but it is not really clear to me what the problem is. Cheers Edgar
Posted: 3 years ago 28.02.2022, 09:04 GMT-5
I have fixed this problem.
Thanks for COMSOL Technical Support's help and here attached the solution:
If I understand correctly, you would like to assign the temperature to a whole domain? If this is the case, I believe that such a domain does not need to be included in the simulation, only its boundaries connecting to other domains. Those boundaries can be assigned a temperature thanks to a Temperature boundary condition.
Also thanks for Edgar J. Kaiser's reply.
I have fixed this problem. Thanks for COMSOL Technical Support's help and here attached the solution: If I understand correctly, you would like to assign the temperature to a whole domain? If this is the case, I believe that such a domain does not need to be included in the simulation, only its boundaries connecting to other domains. Those boundaries can be assigned a temperature thanks to a Temperature boundary condition. Also thanks for Edgar J. Kaiser's reply.
