error in the model of a coax
I'm a newbie on comsol, trying to model in ac/dc module and electromagnetics.
I started to work with a simple coax cable structure, examined the capacitance wrt radius of insulator as well as different different types of insulators in electrostatics physics. Then studied the tutorial on the empedance of a coax cable.
Now, what I want to is to apply an ac voltage to its conductors and see how it behaves.
However I couldn't do it. First, I solved the problem in time domain of electrostatics and electric currents separately, as seting the terminal voltage a function depended on time, i.e. Vo*sin(2*pi*f*t).
When those did not work, I switched to the freq.domain in electric currents. However, that did not work, either.
This is the error I'm getting,
Problem encountered during results while solving.
Evaluation of result expression failed.
Failed to evaluate variable.
- Variable: es.nD
- Geometry: 1
- Boundary: 6 7 8 9 10 11 26 27 28 42 43 44
- Expression: real(es.nD)
What might be the problem?
thanks a lot
CBD
1 Reply Last Post 12.07.2012, 15:39 GMT-4
Posted: 1 decade ago 12.07.2012, 15:39 GMT-4
Hi again,
I managed my problem, solved it. However now I have a different problem.
I designed a model with a semi-conductor sphere and studied the currents flown on the surface with ec physics. When I add an air around the sphere, that did not work simply. The program couldn't calculate.
thanks,
Ceren
Hi again, I managed my problem, solved it. However now I have a different problem. I designed a model with a semi-conductor sphere and studied the currents flown on the surface with ec physics. When I add an air around the sphere, that did not work simply. The program couldn't calculate. What might be the problem? thanks, Ceren
