contact with friction
Hey,
I´m trying to model a ceramik block that slide on a second ceramik block.
The distance between the first and the second block is 0.001 m.
In the middle of the lower edge of the first block I set a fixed constraint.
The two blocks are set up as a contact pair, and a static coulomb friction is set.
The first block has a body load of (-rho*gravity).
my problems are:
- the upper block does not reach the lower.
- result = no friction
Has someone an example?
Thanks for tips
Daniel
0 Replies Last Post 05.07.2012, 09:50 GMT-4
Hello Daniel Old
