Mapping the variable from 2D axisymmetric to 3D geometry
Posted 03.11.2021, 02:22 GMT-4 Low-Frequency Electromagnetics Version 5.5 0 Replies
I am trying to map the losses from a 2D axisymmetric model to a 3D geometry. The losses are calculated in a 2D magnetic field interface and given as a heat source in a 3D heat transfer model.
I am using the general extrusion operator for mapping. Somehow, the losses are not getting correctly mapped into the 3D geometry. Is there anything I should take into account here?
Note: I am specifically interested in using the extrusion operator in this example. In fact, I created this model to check the working of general extrusion.
I have attached the mph file herewith.
Thank you.
Regards
Hello Pranoti Raut
