How to get rid of negative values of concentration?
I'm working on a vapor intrusion model in which the contaminant is moving in soil. The simulation is time dependent and I have used Darcy's law and solute transport in order to apply governing equations. After computing the model, I have negative values for concentration somewhere, that they are not ignorable. This problem is more sensible for last time steps (about one year). I don't know how to solve this. Is there any problem with my boundary conditions or mesh size?
If anyone can help me I will really appreciate it.
Simin
2 Replies Last Post 27.06.2012, 16:54 GMT-4
Posted: 1 decade ago 27.06.2012, 15:04 GMT-4
for me un-physical diffusion equation variables are mostly related to mesh density, material diffusivity and time stepping issues, these are linked.
But I have seen several "tricks" on the Forum how to help the solver to come over such errors. Even if I wonder how correct the results are (at least locally) when using these tricks, instead of checking the above three variables. try a search, one response was here
www.comsol.eu/community/forums/general/thread/29200/#p81519
Hi for me un-physical diffusion equation variables are mostly related to mesh density, material diffusivity and time stepping issues, these are linked. But I have seen several "tricks" on the Forum how to help the solver to come over such errors. Even if I wonder how correct the results are (at least locally) when using these tricks, instead of checking the above three variables. try a search, one response was here http://www.comsol.eu/community/forums/general/thread/29200/#p81519 -- Good luck Ivar
Posted: 1 decade ago 27.06.2012, 16:54 GMT-4
Thank you very much, that works. Now I just need to make sure about the reliability of data.
Thanks a lot again
Thank you very much, that works. Now I just need to make sure about the reliability of data. Thanks a lot again
