Create Equation
In COMSOL it's given the wave equation (file 1) - PDE waeq
but I want to use other form of this equation (see file 2)
this means I need to create or modify the equation in the COMSOL
how can I do that?
3 Replies Last Post 08.06.2013, 22:55 GMT-4
Posted: 1 decade ago 20.06.2012, 16:15 GMT-4
I believe you should start rewriting your equation to match a PDE coefficient equation formulation, then use the PDE physics
Rather than modifying only one equation of a given pre-defined physics, as I'm not sure exactly if you should not then modify several of the predefined linked equations too
Hi I believe you should start rewriting your equation to match a PDE coefficient equation formulation, then use the PDE physics Rather than modifying only one equation of a given pre-defined physics, as I'm not sure exactly if you should not then modify several of the predefined linked equations too -- Good luck Ivar
Posted: 1 decade ago 05.04.2013, 07:06 GMT-4
Hi Ivar,
I am also trying to modify the Anand's model of Viscoplasticity to suit my model. Do you advice me rewriting the whole equation or try to modify the equation? In case to modify, could you please help me as how can I modify it .
Pavan Kumar G
BITS Pilnai Hyderabad Campus
Hi Ivar, I am also trying to modify the Anand's model of Viscoplasticity to suit my model. Do you advice me rewriting the whole equation or try to modify the equation? In case to modify, could you please help me as how can I modify it . Pavan Kumar G BITS Pilnai Hyderabad Campus
Jânio Anselmo Engenharia Biomédica
Posted: 1 decade ago 08.06.2013, 22:55 GMT-4
Hi Joquin Santos and Pavan Kumar Gurrala
Did you solve your problems? I need to do the same thing! If you can could help me?
Hi Joquin Santos and Pavan Kumar Gurrala Did you solve your problems? I need to do the same thing! If you can could help me?
