Creating spatially-dependent material properties from file via LiveLink for Matlab
Hi All,
I'm using the RF module and LiveLink for Matlab to perform 2D mode solving of nanoscale optical waveguides. I would like one of my domains to have a material property (refractive index) that is a dependent on position, but that can not be expressed as a function of position - rather, I need to import this material property from Matlab.
The good news is that the index profile is a function of a previous COMSOL calculation on the same grid (the goal is to iteratively solve for the modes of a waveguide with nonlinear index). It's trivial to create a structure in Matlab that contains all of the required data. My problem is, I can't figure out how to send this information back to COMSOL to set a material property with spatial dependence. I'm guessing that I need the model.material() function, but I can't get my head around the syntax..
Any suggestions?
5 Replies Last Post 07.06.2012, 17:19 GMT-4
Posted: 1 decade ago 07.06.2012, 04:26 GMT-4
It is possible. I have not tried to read in a grid from a matlab array directly. But I have tried to read in a grid from a text file which is re-written at each time step as part of MATLAB calculation and essentially contains: x, y, f(x,y).
Based on livelink manual, for example, I just show you the creation of a text file called ksoft.txt
% Open the file ksoft.txt for writting and enter the
% evaluated data with the format '%%x y ksoft'. Exclude in the file the NaN
% value that result of evaluating the ksoft outside the domain.
fid = fopen(filename1,'w');
fprintf(fid,'%%x y ksoft\n');
for j = 1:nog
if ~isnan(x1(j))||~isnan(y1(j))
fprintf(fid,'%10.10f %10.10f %10.10f\n',x1(j),y1(j),ksoft1(j));
end
end
fclose(fid);
I then have the following two lines:
model.func('int1').setIndex('funcs', 'int2', 0, 0);
model.study('std1').run;
To know what the int2 is doing, I attach a screenshot.
I guess that implementing directly from MATLAB array should also be simple but I have not had time to do it.
Sorry I cannot be of more help.
Suresh
Hi, It is possible. I have not tried to read in a grid from a matlab array directly. But I have tried to read in a grid from a text file which is re-written at each time step as part of MATLAB calculation and essentially contains: x, y, f(x,y). Based on livelink manual, for example, I just show you the creation of a text file called ksoft.txt %% % Open the file ksoft.txt for writting and enter the % evaluated data with the format '%%x y ksoft'. Exclude in the file the NaN % value that result of evaluating the ksoft outside the domain. fid = fopen(filename1,'w'); fprintf(fid,'%%x y ksoft\n'); for j = 1:nog if ~isnan(x1(j))||~isnan(y1(j)) fprintf(fid,'%10.10f %10.10f %10.10f\n',x1(j),y1(j),ksoft1(j)); end end fclose(fid); I then have the following two lines: model.func('int1').setIndex('funcs', 'int2', 0, 0); model.study('std1').run; To know what the int2 is doing, I attach a screenshot. I guess that implementing directly from MATLAB array should also be simple but I have not had time to do it. Sorry I cannot be of more help. Suresh
Posted: 1 decade ago 07.06.2012, 14:36 GMT-4
Hi Suresh,
Thanks for your suggestion, I'll give it a try. I don't have any problem with going from Matlab to COMSOL via a .txt file.
Would I complete the task simply by setting my material parameter to 'ksoft', using your example?
Cheers,
Brian
Hi Suresh, Thanks for your suggestion, I'll give it a try. I don't have any problem with going from Matlab to COMSOL via a .txt file. Would I complete the task simply by setting my material parameter to 'ksoft', using your example? Cheers, Brian
Posted: 1 decade ago 07.06.2012, 15:47 GMT-4
Suresh,
I'm not quite sure what your last 2 lines accomplish. I managed to get COMSOL to read and interpolate the .txt file by setting up int1 and the variable by hand in COMSOL, but I need to be able to set these through MATLAB (since it's going to iterate in a MATLAB loop). Any thoughts?
Brian
Suresh, I'm not quite sure what your last 2 lines accomplish. I managed to get COMSOL to read and interpolate the .txt file by setting up int1 and the variable by hand in COMSOL, but I need to be able to set these through MATLAB (since it's going to iterate in a MATLAB loop). Any thoughts? Thanks, Brian
Posted: 1 decade ago 07.06.2012, 15:59 GMT-4
I'd suggest to avoid using interpolation function in this case. It's rather slow/inaccurate. Instead, call Matlab function directly from COMSOL (Global def.-Functions-Matlab).
Input to the function should be xyz coordinates (vectors) and output is the function value (vector of the same size). I define electric fields in such a way and it's so much faster and accurate than doing through text files.
I'd suggest to avoid using interpolation function in this case. It's rather slow/inaccurate. Instead, call Matlab function directly from COMSOL (Global def.-Functions-Matlab). Input to the function should be xyz coordinates (vectors) and output is the function value (vector of the same size). I define electric fields in such a way and it's so much faster and accurate than doing through text files.
Posted: 1 decade ago 07.06.2012, 17:19 GMT-4
Hi Brian,
I am not sure of your question.
All the lines I gave you are to be written into a program file that you create in matlab.
If you are loading filename.m file then the interpolation command would already be in the m file itself so you probably don't need it. This script and many more would be necessary if you are writing out the entire script yourself without calling the m file.
The next line "model.study('std1').run;" is necessary because I have to run the model. What I showed you was just an extract from a much larger matlab input file. I have a lot more scripting to effect changes at every time step within a loop and therefore I run the model after changing them. I am not sure if I understood your question correctly here. So I attach here again a partial code that may help you a bit more.
Alexander is right that it is better to call matlab array directly, because in this approach, as you have guessed you have to keep writing data into a text file at each step of the loop. I think this could be slow. I had no problems with accuracy at least for the problem I was solving, it also depends on how many data points you have.
Suresh
clear
% have to load mph here
model = mphload('modelname'); % no need to put .mph extension to the modelname
% allocate arrays and initialise ksoft
filename1='D:\My_research\ksoft.txt';
pd1=mpheval(model,'u','pattern','gauss');
nog=length(pd1.p(1,:));
ksoft1=zeros(nog,1);
ksoft1(:)=1e-4;
x1=pd1.p(1,:);
y1=pd1.p(2,:);
for j = 1:nog
end
end
fclose(fid);
% Run a loop
for i = 1:50
% set parameter values
model.param.set('bound_disp', i*1e-6);
for iter = 1:2
% Run the study.
if (iter>1)
model.param.set('param1',1);
model.param.set('param2',1);
else
model.param.set('param1',0);
model.param.set('param2',0);
end
% re-evaluate ksoft
script deleted
% re-write ksoft.txt
script deleted
% Set the new solution vector back into comsol, reset only the last time
% % step value
model.sol('sol1').setU(Ulast);
model.sol('sol1').createSolution;
model.sol('sol1').feature('v1').set('initmethod', 'sol');
model.sol('sol1').feature('v1').set('initsol', 'sol1');
disp(sprintf(' Completed iteration no. - %d',iter));
end
disp(sprintf('Completed load step. - %d',i));
end
end
disp(sprintf('Problem completed. %d'));
Hi Brian, I am not sure of your question. All the lines I gave you are to be written into a program file that you create in matlab. If you are loading filename.m file then the interpolation command would already be in the m file itself so you probably don't need it. This script and many more would be necessary if you are writing out the entire script yourself without calling the m file. The next line "model.study('std1').run;" is necessary because I have to run the model. What I showed you was just an extract from a much larger matlab input file. I have a lot more scripting to effect changes at every time step within a loop and therefore I run the model after changing them. I am not sure if I understood your question correctly here. So I attach here again a partial code that may help you a bit more. Alexander is right that it is better to call matlab array directly, because in this approach, as you have guessed you have to keep writing data into a text file at each step of the loop. I think this could be slow. I had no problems with accuracy at least for the problem I was solving, it also depends on how many data points you have. Suresh ------------------------------------------------ clear %% % have to load mph here model = mphload('modelname'); % no need to put .mph extension to the modelname % allocate arrays and initialise ksoft filename1='D:\My_research\ksoft.txt'; pd1=mpheval(model,'u','pattern','gauss'); nog=length(pd1.p(1,:)); ksoft1=zeros(nog,1); ksoft1(:)=1e-4; x1=pd1.p(1,:); y1=pd1.p(2,:); %% % Open the file ksoft.txt for writting and enter the % evaluated data with the format '%%x y ksoft'. Exclude in the file the NaN % value that result of evaluating the ksoft outside the domain. fid = fopen(filename1,'w'); fprintf(fid,'%%x y ksoft\n'); for j = 1:nog if ~isnan(x1(j))||~isnan(y1(j)) fprintf(fid,'%10.10f %10.10f %10.10f\n',x1(j),y1(j),ksoft1(j)); end end fclose(fid); %% % Run a loop for i = 1:50 %% % set parameter values model.param.set('bound_disp', i*1e-6); for iter = 1:2 % Run the study. if (iter>1) model.param.set('param1',1); model.param.set('param2',1); else model.param.set('param1',0); model.param.set('param2',0); end model.func('int1').setIndex('funcs', 'int2', 0, 0); model.study('std1').run; % re-evaluate ksoft script deleted % re-write ksoft.txt script deleted %% % Set the new solution vector back into comsol, reset only the last time % % step value model.sol('sol1').setU(Ulast); model.sol('sol1').createSolution; model.sol('sol1').feature('v1').set('initmethod', 'sol'); model.sol('sol1').feature('v1').set('initsol', 'sol1'); disp(sprintf(' Completed iteration no. - %d',iter)); end disp(sprintf('Completed load step. - %d',i)); end end disp(sprintf('Problem completed. %d'));
