Applying a temperature varying with time
Hi I have modeled a bottle with water inside and I want to apply a temperature at the bottom of the bottle which varies with time. I have made a table with temperature vs time.
How do I apply this as a temperature load?
2 Replies Last Post 16.06.2021, 05:34 GMT-4
Magnus Ringh COMSOL Employee
Posted: 3 years ago 14.06.2021, 07:22 GMT-4
Updated: 3 years ago 14.06.2021, 07:23 GMT-4
This is straightforward. Define the table as a Interpolation function with seconds as the input argument and kelvin as the output (function) argument. If the function is called temp_vs_time, for example, enter it as the temperature in the Temperature node that is active at the bottom of the bottle as temp_vs_time(t).
Magnus Ringh
Hi, This is straightforward. Define the table as a Interpolation function with seconds as the input argument and kelvin as the output (function) argument. If the function is called `temp_vs_time`, for example, enter it as the temperature in the **Temperature** node that is active at the bottom of the bottle as `temp_vs_time(t)`. Best regards, Magnus Ringh
Posted: 3 years ago 16.06.2021, 05:34 GMT-4
Updated: 3 years ago 16.06.2021, 05:38 GMT-4
Do I define a function under Defintions? If so, when I enter my function name as you stated (e.g. temp_vs_time(t)) I get a yellow highligh stating that its an unexpected unit of input.
EDIT: Never mind I forgot the units...
Do I define a function under Defintions? If so, when I enter my function name as you stated (e.g. temp_vs_time(t)) I get a yellow highligh stating that its an unexpected unit of input. EDIT: Never mind I forgot the units...
