Lamb Wave Propagation
Requesting some guidance on building a model of an isotropic 2D plate undergoing ultrasonic lamb wave propagation. So far I have approached the problem by applying a timedependent, 5-cycle point load, but the proper longitudinal and shear waves (S0 and A0) are not generated. Does anyone have experience with this? I have reviewed the comsol literature but have not been successful with this yet.
Another approach would be manually generating waves with the proper group and phase speeds, but I am worried that wave-dispersion would not be modeled properly (also, I am unsure of how to impose the waves).
Please let me know if anyone has input for me-- whether it be anecdotal, perscriptive, or simply a good resource. Thanks.
1 Reply Last Post 01.05.2021, 19:57 GMT-4
Dave Greve Certified Consultant
Posted: 3 years ago 01.05.2021, 19:57 GMT-4
Updated: 3 years ago 01.05.2021, 19:58 GMT-4
I believe there are a fair number of publications on this. For example an old one
https://users.ece.cmu.edu/~dwg/research/Waves25rev.pdf
Publications won't get you example .mph file though. And the settings required will change with different versions of Comsol.
Some advice about settings for transient analysis (5.6)
BDF solver, max order 2, min order 1, strict time stepping
If that doesn't work then (1) explain exactly how it doesn't work and (2) post your model.
I believe there are a fair number of publications on this. For example an old one https://users.ece.cmu.edu/~dwg/research/Waves25rev.pdf Publications won't get you example .mph file though. And the settings required will change with different versions of Comsol. Some advice about settings for transient analysis (5.6) BDF solver, max order 2, min order 1, strict time stepping If that doesn't work then (1) explain exactly how it doesn't work and (2) post your model.
