20.05.2012, 09:14 GMT-4
I suspect its your .r^2 .r I assume you mean *r^2 and *r, no ?
20.05.2012, 09:53 GMT-4
yes Ivar its *r. Moreover I should use d(Ez,r) for differentiation. i have changed this but i get zero answer. probably its not understanding radial derivative. whats the way to implement that.
thanks
Deepak
thanks
Deepak
20.05.2012, 10:40 GMT-4
you need to write out the cylindrical coordinate differential from the x and y derivatives. By the way normally you have alread Exx and Exy ... defined
you can define a cylindrical coordinate system to express your sys2.r
Unfortunately COMSOL does not understand d(Ex,sys2.r)
You could also then consider using a higher discretization order to try to get smoother results
17.12.2012, 14:31 GMT-5
Could u give me the file on bending fiber in v 4.2.
Thanks in advance.
Thanks in advance.
