PDE equation
I am using comsol's pde equation for electrothermal coupling, currently I want to use the parameters from the material library in the pde equation, how can I achieve this?
1 Reply Last Post 23.03.2021, 05:07 GMT-4
Magnus Ringh COMSOL Employee
Posted: 4 years ago 23.03.2021, 05:07 GMT-4
If the material property does not dependent on temperature, you can use it in a PDE coefficient as mat1.def.Cp, for example, which represents the heat capacity in a material with the name mat1. If there is a temperature dependence, you can define a parameter for the temperature and pass that or a numerical value as an argument for the temperature, when it is not a dependent variable T that you solve for.
Magnus Ringh
Hi, If the material property does not dependent on temperature, you can use it in a PDE coefficient as `mat1.def.Cp`, for example, which represents the heat capacity in a material with the name `mat1`. If there is a temperature dependence, you can define a parameter for the temperature and pass that or a numerical value as an argument for the temperature, when it is not a dependent variable `T` that you solve for. Best regards, Magnus Ringh
