Magnetic Fields Lower Than Expected
Hello, I have been simulating the magnetic field for a Hall Effect thruster but I am getting much lower mangnetic field strengths in the channel than I am expecting. Is there a reason for this? Also if I run an axisymmetric design which is similar in FEMM then I get a magentic field strength which is ten times greater than COMSOL is giving me. Why would this be, I belive I have set the simulations up with the same properties and everything.
Thank you Hazel
2 Replies Last Post 12.02.2021, 09:54 GMT-5
Posted: 3 years ago 08.02.2021, 11:00 GMT-5
Updated: 3 years ago 08.02.2021, 11:04 GMT-5
There are too many possibilities. Since you seem to have these two separate computational tools available, I suggest you model (with both codes) something otherewise similar, but where you already know the answer beforehand to good accuracy (e.g., to better than a factor of 2). Then you can at least decide which (if either) code is correct. When answers differ by a factor of ten, it is often (not always) easy to identify one that is simply wrong. If/when you decide that the Comsol model is the one with the wrong answer, then I encourage you to post your model to the forum, so it can be examined by others here in detail.
There are too many possibilities. Since you seem to have these two separate computational tools available, I suggest you model (with both codes) something otherewise similar, but where you already *know* the answer beforehand to good accuracy (e.g., to better than a factor of 2). Then you can at least decide which (if either) code is correct. When answers differ by a factor of ten, it is *often* (not always) easy to identify one that is simply wrong. If/when you decide that the Comsol model is the one with the wrong answer, then I encourage you to post your model to the forum, so it can be examined by others here in detail.
Posted: 3 years ago 12.02.2021, 09:54 GMT-5
I belive that it is the COMSOL model which is giving me the incorrect values, and so have attched an inital simulation with five coils as an example.
