How to plot potential along semi-circular arc
I am simulating a model with a charge at potential 5000V at the centre of a circle of radius 5m in 2D axis-symmetric mode. I would like to plot a line graph of how the electric potential varies along an arc of radius 2m inside this circle. How can I do so?
I'm a new user to COMSOL and would appreciate any help.
1 Reply Last Post 28.01.2021, 13:09 GMT-5
Posted: 3 years ago 28.01.2021, 13:09 GMT-5
Assuming you already have the rest of the model setup with appropriate boundary conditions to compute the potential everywhere, and that it works fine, then: 1. Go back to the Geometry section. Draw the arc. I am presuming you mean the arc to be in the r-z plane. (Right?) 2. Re-mesh and re-execute the problem. 3. Under Results, create a 1D plot group. Add a line graph to it. Choose the arc as the selection for the line graph. 4. Plot your answer. I've attached an example which should be similar enough.
