Inconsistency in the definition of Reference Frame in COMSOL?
The definition of Reference coordinate system in COMSOL is a little confusing for me. I have seen two or more statements in the user manual which in my opinion are not consistent. Are the following statements from the manual talking about the same thing? One states Spatial Frame=Reference Configuration, while the other one says Material Coordinate Sys= Reference Coord:
1-
In COMSOL Multiphysics > Definitions > Coordinate Systems:
SETTINGS
Select a Frame type—Reference configuration, or Deformed configuration (the default). The deformed configuration follows the material whereas the reference configuration is attached to the spatial frame.
2-
COMSOL Multiphysics > The Deformed Geometry and Moving Mesh Interfaces > Deformed Mesh Fundamentals
FRAMES
COMSOL Multiphysics refers to the spatial, material/reference, geometry, and mesh coordinate systems described above as spatial frame, material frame (reference frame), geometry frame, and mesh frame, respectively.
Thank you.
Jessica
4 Replies Last Post 07.04.2012, 05:52 GMT-4
Posted: 1 decade ago 05.04.2012, 12:32 GMT-4
I believe that comes from the fact that COMSOL has changed a little the naming andmore the use of the different frames while going from version 3.5 to 4.2a. Today, you should talk about spatial, material, mesh and geometric frames. The geometric frame is the lowest level and exist for itself only if you use the "dg" (deformed geometry), it maps your geometry FEM Entities to the material frame entities (by defaults it's identity). The spatial frame exist for it's own (dissociates from the material frame) in "Solid" physics, if so the lower case x,y,z,r spatial frame corresponds to x = X+u etc (at east when non-linear large displacement geometry is selected) where X is the Material coordinate frame name. The mesh frame dissociates from the others in "deformed mesh" physics when you start to remesh. I beleive it 's definition and use might still change in the next version, we will see (I'm not COMSOL so I do not know all the interiousr, nor the to comes ;) as it's sometimes overlappng with the use of the spatial frame.
Reference frame was used in 3.5, I understand it's to be renamed to material frame in 4.2 (but there might be exceptions). So far I have noticed too that the doc is not always fully consistent with latest 4.2a changes so I'm often confused too. I have found the recent book of E.B Tadmor: Continuum Mechanics and Thermodynamics" CUP 2012, to have an extensive discussions about tensor geometry and frames, very close to COMSOL's notation.
Anyhow, when I have a doubt, I make simple models, squares ontop of each others with "soft material properties, then I sweeze them with an adequate pressure load, and select to integrate volumes over the different frames. Also to see if the frames are dissociated (by default all have lower case letters x,y,z,r (and changes names only if different from an identity mapping) by calling for a new coordinate frame, then you can select whic of the for to use and there you notice the aming convention, depending of the physics these are all lower case, or appear with the different lower, upper, _M or _G suffixes.
Hi I believe that comes from the fact that COMSOL has changed a little the naming andmore the use of the different frames while going from version 3.5 to 4.2a. Today, you should talk about spatial, material, mesh and geometric frames. The geometric frame is the lowest level and exist for itself only if you use the "dg" (deformed geometry), it maps your geometry FEM Entities to the material frame entities (by defaults it's identity). The spatial frame exist for it's own (dissociates from the material frame) in "Solid" physics, if so the lower case x,y,z,r spatial frame corresponds to x = X+u etc (at east when non-linear large displacement geometry is selected) where X is the Material coordinate frame name. The mesh frame dissociates from the others in "deformed mesh" physics when you start to remesh. I beleive it 's definition and use might still change in the next version, we will see (I'm not COMSOL so I do not know all the interiousr, nor the to comes ;) as it's sometimes overlappng with the use of the spatial frame. Reference frame was used in 3.5, I understand it's to be renamed to material frame in 4.2 (but there might be exceptions). So far I have noticed too that the doc is not always fully consistent with latest 4.2a changes so I'm often confused too. I have found the recent book of E.B Tadmor: Continuum Mechanics and Thermodynamics" CUP 2012, to have an extensive discussions about tensor geometry and frames, very close to COMSOL's notation. Anyhow, when I have a doubt, I make simple models, squares ontop of each others with "soft material properties, then I sweeze them with an adequate pressure load, and select to integrate volumes over the different frames. Also to see if the frames are dissociated (by default all have lower case letters x,y,z,r (and changes names only if different from an identity mapping) by calling for a new coordinate frame, then you can select whic of the for to use and there you notice the aming convention, depending of the physics these are all lower case, or appear with the different lower, upper, _M or _G suffixes. -- Good luck Ivar
Posted: 1 decade ago 05.04.2012, 12:59 GMT-4
Hi Ivar,
As always, thank you.
Jessica
Hi Ivar, As always, thank you. Jessica
Posted: 1 decade ago 05.04.2012, 14:21 GMT-4
Ivar,
As you suggested, I decided to create a simple model to check the frames and their effects. So I created a simple beam with the length of 1m, fixed one end and applied a displacement of 0.001 to the other end. Under my Solid Mechanics physics, I set the Frame Type, Material, under Discretization.
The way COMSOL defines Material Coordinate Sys. is that they consider it as if it is printed on the geometry. So with this definition, I expected to get displacement (u) = 0 with Material coordinate system. Therefore, in order to see the actual deformation (u= 0.001m), I thought I need to switch to Spatial coordinate.
After computing the problem, the displacement (u) of the free end of the beam was 0.001m (when using Material Frame), which is not what I expected. Next, I changed the frame type to Spatial, under Discretization, and I got the same results, I even thought maybe I have to change the frame types under Data Set\Solution, and under 2D Plot Group in order to see the potential changes from 0.001m, but No Change.
So, I was wondering how we can see the difference between the effects of these two frames.
I have attached the mph file.
Thanks you.
Jessica,
Ivar, As you suggested, I decided to create a simple model to check the frames and their effects. So I created a simple beam with the length of 1m, fixed one end and applied a displacement of 0.001 to the other end. Under my Solid Mechanics physics, I set the Frame Type, Material, under Discretization. The way COMSOL defines Material Coordinate Sys. is that they consider it as if it is printed on the geometry. So with this definition, I expected to get displacement (u) = 0 with Material coordinate system. Therefore, in order to see the actual deformation (u= 0.001m), I thought I need to switch to Spatial coordinate. After computing the problem, the displacement (u) of the free end of the beam was 0.001m (when using Material Frame), which is not what I expected. Next, I changed the frame type to Spatial, under Discretization, and I got the same results, I even thought maybe I have to change the frame types under Data Set\Solution, and under 2D Plot Group in order to see the potential changes from 0.001m, but No Change. So, I was wondering how we can see the difference between the effects of these two frames. I have attached the mph file. Thanks you. Jessica, [QUOTE] Hi I believe that comes from the fact that COMSOL has changed a little the naming andmore the use of the different frames while going from version 3.5 to 4.2a. Today, you should talk about spatial, material, mesh and geometric frames. The geometric frame is the lowest level and exist for itself only if you use the "dg" (deformed geometry), it maps your geometry FEM Entities to the material frame entities (by defaults it's identity). The spatial frame exist for it's own (dissociates from the material frame) in "Solid" physics, if so the lower case x,y,z,r spatial frame corresponds to x = X+u etc (at east when non-linear large displacement geometry is selected) where X is the Material coordinate frame name. The mesh frame dissociates from the others in "deformed mesh" physics when you start to remesh. I beleive it 's definition and use might still change in the next version, we will see (I'm not COMSOL so I do not know all the interiousr, nor the to comes ;) as it's sometimes overlappng with the use of the spatial frame. Reference frame was used in 3.5, I understand it's to be renamed to material frame in 4.2 (but there might be exceptions). So far I have noticed too that the doc is not always fully consistent with latest 4.2a changes so I'm often confused too. I have found the recent book of E.B Tadmor: Continuum Mechanics and Thermodynamics" CUP 2012, to have an extensive discussions about tensor geometry and frames, very close to COMSOL's notation. Anyhow, when I have a doubt, I make simple models, squares ontop of each others with "soft material properties, then I sweeze them with an adequate pressure load, and select to integrate volumes over the different frames. Also to see if the frames are dissociated (by default all have lower case letters x,y,z,r (and changes names only if different from an identity mapping) by calling for a new coordinate frame, then you can select whic of the for to use and there you notice the aming convention, depending of the physics these are all lower case, or appear with the different lower, upper, _M or _G suffixes. -- Good luck Ivar [/QUOTE]
Posted: 1 decade ago 07.04.2012, 05:52 GMT-4
that is not how I would have checked, for me the resulting x = X+u, where x is the spatial frame coordinate and X the material frame coordinate. u is the solve displacement along the X coordinate hence remains u=0.001
I never play with the discretisation coordnate, so I would have to look into exactly what that does.
But I often integrate over either spatial or material frames depending on what I want to get out and there you do not get the same results depending on what you select. Check also the effect of the "geometric non linearity check box in the solver tab of 4.2a
By the way try a search on "Frame" on the forum, this has been discussed a couple of times, and I believe I left a few example models once, but pls check again carefully, as things have changed somewhat with COMSOL between the latest versions
Hi that is not how I would have checked, for me the resulting x = X+u, where x is the spatial frame coordinate and X the material frame coordinate. u is the solve displacement along the X coordinate hence remains u=0.001 I never play with the discretisation coordnate, so I would have to look into exactly what that does. But I often integrate over either spatial or material frames depending on what I want to get out and there you do not get the same results depending on what you select. Check also the effect of the "geometric non linearity check box in the solver tab of 4.2a By the way try a search on "Frame" on the forum, this has been discussed a couple of times, and I believe I left a few example models once, but pls check again carefully, as things have changed somewhat with COMSOL between the latest versions -- Good luck Ivar
