Which function or command in COMSOL 4.2 is equivalent to "femsol"
I set up a COMSOL 4.2 model to do parameter sweep (Assume parameter name is "n") simulation. For each parameter n(i), I have to update the model coefficients using an interpolation function, and then start to simulate n(i+1). The process is similar to "time-dependent" condition, the only difference is I use a dimensionless "n" instead of t.
In COMSOL 3.5, I just add a loop for parameter n behind the "mesh" section, and use "asseminit", "femsol" and "femstatic" inside this loop to obtain simulation results step by step.
But when I save my model as m.file in COMSOL 4.2, I cannot find any functions.
Problem:
1) How can I control the parameter sweep simulation in Matlab and obtain results and update coefficients step by step?
2) What function or commands are equivalent to those functions I mentioned above?
3) In COMSOL 3.5, I just add my own solution method following meshextend command. Can I delete model.study and model.result in COMSOL 4.2, if the postprocessing is done in matlab?
Thanks a lot
Dan
0 Replies Last Post 07.03.2012, 09:49 GMT-5
Hello Zhangxian Deng
