Parametric sweep changing mesh hmax: sweep in batch or solver node?
where is the proper place for a parametric sweep node which runs a (stationary) study for several hmax values for the mesh?
model.sol(<solname>).feature(<fname>).feature.create('p1','Parametric');
or
model.batch.create('p1', 'Parametric');
Best regards
4 Replies Last Post 05.03.2012, 14:42 GMT-5
Posted: 1 decade ago 04.03.2012, 10:12 GMT-5
Just found out that parametric sweep that alters a mesh or geometry parameter has to be a batch-node sweep, a solver-sweep won't work.
Posted: 1 decade ago 04.03.2012, 17:34 GMT-5
In the GUI you need to add tha Parametric Sweep node before the solver node to get around the geoemtry and/or mesh. The solver swep (continuation) does NOT loop around the geoemtry nor mesh.
Another difference: the contination sweep uses the initial condition of sweep "n" to start sweep "n+1", while the parametric swep start from orignal initial conditions for EACH step
Hi In the GUI you need to add tha Parametric Sweep node before the solver node to get around the geoemtry and/or mesh. The solver swep (continuation) does NOT loop around the geoemtry nor mesh. Another difference: the contination sweep uses the initial condition of sweep "n" to start sweep "n+1", while the parametric swep start from orignal initial conditions for EACH step -- Good luck Ivar
Posted: 1 decade ago 05.03.2012, 07:24 GMT-5
Hi, thank you for the explaination.
There is something mentioned in the 'LiveLink for Matlab UserGuide' (chapter 'Running the Model in a Loop'):
'To automatically vary the value of geometry settings or to combine a parametric analysis with a time-dependent or eigenfrequency study, create a batch node that contains a parametric feature.'
Then they are using a batch node and two solution sets for the sweep. In my code I did it like this and it seems to work. Is that eqal to your approach in the GUI?
Hi, thank you for the explaination. There is something mentioned in the 'LiveLink for Matlab UserGuide' (chapter 'Running the Model in a Loop'): 'To automatically vary the value of geometry settings or to combine a parametric analysis with a time-dependent or eigenfrequency study, create a batch node that contains a parametric feature.' Then they are using a batch node and two solution sets for the sweep. In my code I did it like this and it seems to work. Is that eqal to your approach in the GUI?
Posted: 1 decade ago 05.03.2012, 14:42 GMT-5
Probably, but I do not have more knowledge than you to tell that exactly, and since V4 I hardly use matlab, so there are many things in the new inerface that I have not tested out
Hi Probably, but I do not have more knowledge than you to tell that exactly, and since V4 I hardly use matlab, so there are many things in the new inerface that I have not tested out -- Good luck Ivar
