Time Dependent model
I m trying to run a simple time dependent model where i m streching a rectangular plate with an edge load defined as '800[N/m*s]*t[s]'. Unfortunately, i get this error:
Failed to evaluate operator Jacobian.
- Operator: mean
- Geometry: 1
- Boundary: 1
Mean operator requires an adjacent domain of higher dimension.
Can anyone please help?
thx
1 Reply Last Post 29.01.2012, 14:01 GMT-5
Posted: 1 decade ago 29.01.2012, 14:01 GMT-5
without the odel it's difficult to tell, it has to do with the equation you have defined, that Comsol cannot derive to get a Jacobian, but the rest about "mean" (that is probably used internally to get some other COMSOL variable) could indicate a geoemtry coherence issue
by the way i suppose your eqution in the GUi is something like
800[N/m]*t[1/s] or 800[N/m/s]*t
as by default with a time dependent solver "t" is already defined with units of seconds so its not required in the equation field. But I agree its coherent to write it out like you did here on the FORUM to allow us to udnertand the true units of the variables
One point remains I would have expected N/m^2 for a boundary load (even in 2D as there its for 1[m] default depth for the 3rd implicit dimension
Hi without the odel it's difficult to tell, it has to do with the equation you have defined, that Comsol cannot derive to get a Jacobian, but the rest about "mean" (that is probably used internally to get some other COMSOL variable) could indicate a geoemtry coherence issue by the way i suppose your eqution in the GUi is something like 800[N/m]*t[1/s] or 800[N/m/s]*t as by default with a time dependent solver "t" is already defined with units of seconds so its not required in the equation field. But I agree its coherent to write it out like you did here on the FORUM to allow us to udnertand the true units of the variables One point remains I would have expected N/m^2 for a boundary load (even in 2D as there its for 1[m] default depth for the 3rd implicit dimension -- Good luck Ivar
