Robert Koslover
Certified Consultant
27.01.2012, 13:04 GMT-5
Yes. I believe that you will find the following paper very helpful:
Knott, E.F., "Dielectric Constant of Plastic Foams," IEEE Trans. Ant. and Propagat., Vol. 41, No. 8, Aug. 1993, pp. 1167-1171.
Knott shows how to determine the contributions of each material to the overall dielectric constant.
And from that, you can get the index of refraction = square root of epsilon_r.
27.01.2012, 14:14 GMT-5
Thanks Robert, I guess I was just looking at the easiest way to do this using comsol and not by Cuming's approach. I figure I could highlight the area of the cladding (a mixture of air and silica) and get comsol to tell me the volume fraction for each in that region. I could then just plug my silica and air volume fraction into equation 7 in your link and get a good estimate that way. Is there a useful way to do this in comsol or would it just be easier by hand?
27.01.2012, 14:40 GMT-5
to get the volume (or areas in 2D) you need to select the domains, and integrate with an operand of "1"
You can do this in the Results Derived Values section, or define specific variables and an integration operator in the Definition module
Robert Koslover
27.01.2012, 14:44 GMT-5
1. You're welcome!
2. Your planned approach sounds good to me. And yes, unless I really needed to automate the process of having various values for some kind of parameter sweep, I would just enter the refractive index value "by hand."
1. You're welcome!
