Point Evaluation (3d model)
Posted 16.04.2020, 19:22 GMT-4 General, Computational Fluid Dynamics (CFD), Results & Visualization Version 5.5 2 Replies
Hello
I've done some velocity profiles in comsol 5.5 by using 3D cut line option. I want to know exact values of velocity along this cut line on several points. Let's say, some points following Cut Line, equidistantly spaced one from the other, for example a step of 5 cm.
By using Cut point option, then Derived values ----> Point Evaluation, it's possible to read specif values, but it takes so much times coz I'm obliged to do it one by one. I want this to be more automatic, I mean, by defining a step and be able to generate several cut points and evaluate them. I've tried with Array 1D option but it didn't work.
I've read this post and this one, but a exact solution wasn't provided. You can read them if you don't understand my explication of the problem
Maybe someone knows how to overcome this issue??
Thanks, Jhoan
