Difference between acceleration and total acceleration
Hi all,
In multibody dynamics physics I want to generate acceleration of a certain point in the global frame. Among the variables there is 'acceleration' and 'total acceleration' and both consist of 3-axe variable. Just wonder what is the difference between them?
Best regards, Boyue
1 Reply Last Post 13.03.2020, 07:25 GMT-4
Pawan Soami COMSOL Employee
Posted: 4 years ago 13.03.2020, 07:25 GMT-4
Updated: 4 years ago 13.03.2020, 08:08 GMT-4
Hi Boyue,
The 'total acceleration' is defined as the summation of 'acceleration' and ‘frame acceleration'. Frame accelerations could be present in the model when we use Gravity or Rotating Frame nodes.
In the absence of above two nodes or frame accelerations, the acceleration and total acceleration both are the same.
Hope the difference is clear to you.
Pawan Soami
Hi Boyue, The 'total acceleration' is defined as the summation of 'acceleration' and ‘frame acceleration'. Frame accelerations could be present in the model when we use Gravity or Rotating Frame nodes. In the absence of above two nodes or frame accelerations, the acceleration and total acceleration both are the same. Hope the difference is clear to you. Best regards, Pawan Soami
