Different results from line plot
I am plotting the magnetic field at the boundary between two domains. However, I obtain different results depending on which method I use for plotting. I first define a Cut Line 2D on the boundary. I also plot the H-field at the boundary by using the Solution 1 dataset and manually choosing the boundary in the Selection tab. Any idea why the field is different when comparing both methods?
Alex
0 Replies Last Post 06.03.2020, 17:20 GMT-5
Hello Alexandre Arsenault
