running Multiple COMSOL server and Matlab parallel
Dear all, I want to speed up my computations using the parfor loop in MATLAB. Therefore, I called 5 comsol server and use 5 workers in Matlab to connect these comsol servers. Below is the run.sh which called the comsol servers:
#!/bin/sh
#BSUB -q mpi
#BSUB -n 24
#BSUB –o %J.out
#BSUB –e %J.err
killall -9 comsollauncher java
sleep 15s
comsol server -np 1 -silent -port 1036 -tmpdir temporary_files1 &
comsol server -np 1 -silent -port 1046 -tmpdir temporary_files2 &
comsol server -np 1 -silent -port 1056 -tmpdir temporary_files3 &
comsol server -np 1 -silent -port 1066 -tmpdir temporary_files61 &
comsol server -np 1 -silent -port 1076 -tmpdir temporary_files81 &
sleep 60s
matlab -nodisplay -r three_D_aquifer_HPTT_parallel
It seems that when I only use one comsol server, this worked well. But when I use 5 comsol server, it will produce the error like:
java.lang.RuntimeException: Error initializing storage.
Caused by: java.io.FileNotFoundException: /share/home/shixq2/.comsol/v54/configuration/comsol/org.eclipse.osgi/.manager/.fileTableLock (No such file or directory) ......
Do you have any suggestions how to make this work?
Thank you in advance!
Xueyuan
4 Replies Last Post 27.07.2020, 11:32 GMT-4
Hello Xueyuan Kang
Posted: 5 years ago 24.04.2020, 19:15 GMT-4
Updated: 5 years ago 03.06.2020, 01:54 GMT-4
Xueyuan,
I've been working on doing the same as you. I've been able to get this to work by following hints on this comsol forum - https://www.comsol.com/forum/thread/33446/parallel-computing-matlab-comsol. They start Comsol servers within a parfor loop, and then connect each individual parfor worker to a server with the "mphstart" function.
I hope this helps. If you need an example, please let me know.
Alex
Xueyuan, I've been working on doing the same as you. I've been able to get this to work by following hints on this comsol forum - https://www.comsol.com/forum/thread/33446/parallel-computing-matlab-comsol. They start Comsol servers within a parfor loop, and then connect each individual parfor worker to a server with the "mphstart" function. I hope this helps. If you need an example, please let me know. Alex
Posted: 5 years ago 27.07.2020, 11:20 GMT-4
Updated: 5 years ago 27.07.2020, 11:27 GMT-4
Hi, Xueyuan,
I've been working on doing the same as you. Have you solved your problem? In addition to the url that Alex mentioned, another url - http://cn.comsol.com/forum/thread/38557/parallel-computing-with-matlab-livelink-and-comsol?last=2013-07-20T17:37:08Z mentioned a similar solution. But for me, there are still mistakes. for example, when i used the code in the runfile,:
core=2; pp=parpool(core); comsolPort1 = 2036; system( ['D:\COMSOL\COMSOL55\Multiphysics\bin\win64\comsolmphserver.exe -np 1 -port ' num2str(comsolPort1) ' &'] ); pause(1) comsolPort2 = 2037; system( ['D:\COMSOL\COMSOL55\Multiphysics\bin\win64\comsolmphserver.exe -np 1 -port ' num2str(comsolPort2) ' &'] ); pause(1)
and the next code in my function contains my Comsol model :
cd('D:\COMSOL\COMSOL55\Multiphysics\mli') comsolPort=[2036 2037]; t = getCurrentTask() labit=t.ID mphstart(comsolPort(labit))
The calculation of the first round can be performed, but an error will be reported when the second round begins: Error using mphstart Already connected to a server
I thought the first-round model was still occupying ports, so I added the statement "Modelutil.disconnect;", but the calculation again prompted an error: Error using mphstart A connection to COMSOL could not be established. Please check that a COMSOL server is started prior to calling mphstart
I'm confused. Is there anything else to deal with ?
Weikai Xu
Hi, Xueyuan, I've been working on doing the same as you. Have you solved your problem? In addition to the url that Alex mentioned, another url - http://cn.comsol.com/forum/thread/38557/parallel-computing-with-matlab-livelink-and-comsol?last=2013-07-20T17:37:08Z mentioned a similar solution. But for me, there are still mistakes. for example, when i used the code in the runfile,: core=2; pp=parpool(core); comsolPort1 = 2036; system( ['D:\COMSOL\COMSOL55\Multiphysics\bin\win64\comsolmphserver.exe -np 1 -port ' num2str(comsolPort1) ' &'] ); pause(1) comsolPort2 = 2037; system( ['D:\COMSOL\COMSOL55\Multiphysics\bin\win64\comsolmphserver.exe -np 1 -port ' num2str(comsolPort2) ' &'] ); pause(1) and the next code in my function contains my Comsol model : cd('D:\COMSOL\COMSOL55\Multiphysics\mli') comsolPort=[2036 2037]; t = getCurrentTask() labit=t.ID mphstart(comsolPort(labit)) The calculation of the first round can be performed, but an error will be reported when the second round begins: Error using mphstart Already connected to a server I thought the first-round model was still occupying ports, so I added the statement "Modelutil.disconnect;", but the calculation again prompted an error: Error using mphstart A connection to COMSOL could not be established. Please check that a COMSOL server is started prior to calling mphstart I'm confused. Is there anything else to deal with ? Weikai Xu
Posted: 5 years ago 27.07.2020, 11:26 GMT-4
Xueyuan,
Alex
Dear Alex
I am in exactly the same situation as Xueyuan. May I ask how are you solved the problem? In addition to the url that you mentioned, another url - http://cn.comsol.com/forum/thread/38557/parallel-computing-with-matlab-livelink-and-comsol?last=2013-07-20T17:37:08Z mentioned a similar solution. But for me, there are still mistakes. For example, when i used the code in the runfile,:
I'm confused. Is there anything else to deal with ? Could you please kindly share your solution here? Looking forward to your reply very much, Thank you!
Kind regards, Weikai Xu
>Xueyuan, > >I've been working on doing the same as you. I've been able to get this to work by following hints on this comsol forum - https://www.comsol.com/forum/thread/33446/parallel-computing-matlab-comsol. They start Comsol servers within a parfor loop, and then connect each individual parfor worker to a server with the "mphstart" function. > >I hope this helps. If you need an example, please let me know. > >Alex Dear Alex I am in exactly the same situation as Xueyuan. May I ask how are you solved the problem? In addition to the url that you mentioned, another url - http://cn.comsol.com/forum/thread/38557/parallel-computing-with-matlab-livelink-and-comsol?last=2013-07-20T17:37:08Z mentioned a similar solution. But for me, there are still mistakes. For example, when i used the code in the runfile,: core=2; pp=parpool(core); comsolPort1 = 2036; system( ['D:\COMSOL\COMSOL55\Multiphysics\bin\win64\comsolmphserver.exe -np 1 -port ' num2str(comsolPort1) ' &'] ); pause(1) comsolPort2 = 2037; system( ['D:\COMSOL\COMSOL55\Multiphysics\bin\win64\comsolmphserver.exe -np 1 -port ' num2str(comsolPort2) ' &'] ); pause(1) and the next code in my function contains my Comsol model : cd('D:\COMSOL\COMSOL55\Multiphysics\mli') comsolPort=[2036 2037]; t = getCurrentTask() labit=t.ID mphstart(comsolPort(labit)) The calculation of the first round can be performed, but an error will be reported when the second round begins: Error using mphstart Already connected to a server I thought the first-round model was still occupying ports, so I added the statement "Modelutil.disconnect;", but the calculation again prompted an error: Error using mphstart A connection to COMSOL could not be established. Please check that a COMSOL server is started prior to calling mphstart I'm confused. Is there anything else to deal with ? Could you please kindly share your solution here? Looking forward to your reply very much, Thank you! Kind regards, Weikai Xu
Posted: 5 years ago 27.07.2020, 11:32 GMT-4
Hi, all
The format is correct in my reply box, but I don't know why some Enters disappear after submission. I'm sorry for the trouble to you!
Regards, Weikai Xu
Hi, all The format is correct in my reply box, but I don't know why some Enters disappear after submission. I'm sorry for the trouble to you! Regards, Weikai Xu
