sandwich panel and cavity model
Posted 15.12.2011, 23:23 GMT-5 Version 4.0 0 Replies
Hello Guys,
I am modeling a sandwich panel, which is backed by a cavity, in shell, solid mechanics and pressure acoustics module. Sandwich panel is made of two shell elements (two thin plates i.e. top and bottom surface) and the middle portion is the core with zero Poision's ratio (solid mechanics module). And the cavity is by pressure acoustics module. My goal is to calculate sound pressure inside the cavity due to a pressure force on the top surface of the sandwich panel. The frequency of the resonance peaks of the pressure graph inside the cavity is similar to the analytical result. However, the amplitude of the peaks is pretty higher than the analytical result. I am wondering why it is happening.
However, when I am modeling this problem in acosutic-structure interaction, then I am getting almost similar results as my analytical one, but very few peaks are showing in the result. Even if by making zero damping on the top and bottom plates did not show all the peaks.
I am not able to know, where my mistake is. That is why I am posting this message on this forum. I am attaching the model, modeled in both the ways explained above, for your reference. Any kind of advise will be deeply appreciated.
Kiran
Hello Kiran Sahu
